PSDSoft Express and Windows 7
jpadern
Posted on August 18, 2011 at 10:55
Hi there,
I've been trying to install PSDSoft Express in a Windows 7 machine. It appears a message saying that is not a correct Windows version. Does PSDSoft Express works over this OS?
Do you have a solution for this problem? Thanks in advance.
gsbusat
Posted on February 06, 2013 at 19:00
I am using PDSSoft Express 8.66 and have successfully installed it on several Window 7 laptops. You will need administrator rights to install the program.
terry
Posted on October 21, 2013 at 18:36
Did you install this on Win 7 - 64 bit?  32 bit?  Any tricks to it?
I can get the install to get to about 90%, but then it gets the following error:
Setup Error: General File Transfer Error
Please check your target location and try again
Error Number: -37
I'm stuck...  We need to be migrating off of Windows XP, but can't get rid of this PSDexpress.
Anyone have ideas??
Thanks!
Andrew Neil
Posted on December 03, 2013 at 23:08
''We need to be migrating off of Windows XP''
Why?
If you're using a historic target like uPSD, doesn't it make sense to maintain a contemporary, historic development platform?!
