How I can generate random number?
ciccio
Posted on July 23, 2008 at 20:05
ciccio
there are some libraries for generate random integer?
Now I have used srand() and rand() of Hiware.
srand() setting start value.
rand() generate random integer binded of start value.
star value = ADC1 + ADC2
ADC1= humidity sensor
ADC2= temperature sensor
This not very good algorithm :-[
Other solution? Thanks
I use ST325K6.
Bye
harry_rostovtsev
Posted on December 16, 2013 at 06:14
I posted this to another thread about random numbers but since you're looking:
This code uses hardware on the stm32f103 to generate true random numbers without having to add any new hardware: http://www.gniibe.org/memo/development/gnuk/rng/pqrng
You probably can't use this directly but should be pretty easy to modify for your needs.
