2006-03-09 04:37 AM
Package composition for laser inscription
2006-03-09 12:42 AM
This depends on the package you want to use : SO, TQFP, DFN ? To help us to answer can you tell us what is the goal of your question ? BR Laurent2006-03-09 01:15 AM
I need to know what sort of laser machine is needed or laser power to be able to mark the programmed components with some info on top.
2006-03-09 04:37 AM
You can use either CO2 or YAG laser but you must take care to not go deeper than 30 microns else you will damage the connections.
If you need more detailed information, you should contact your distri or a ST sales office and indicate on which kind of package you want to write. Best regards Laurent
