Corrupted icons in STM32F469I-discovery and STM32Cube_FW_F4_V1.14.0
Hi.
Tried building (eclipse + openstm plugins) the demostrator SW supplied in the FW package and it has few problems. Apparently the naming policy has changed and fe gui.h has changed to GUI.h. Similar upper/lower-case naming issues were with many header files.
After solving these problems and successully flashing the dev board, there seems to be problem with the application icons and other graphical items. It seems like composition assumes 32bit content and menu icons are in 16 bit RGB565. I debugged this a bit, and didn't find any obvious problems.
