2023-12-15 01:20 AM
Could you help me to defined a 8 pins component from ST with marking 293F305 . Seem voltage limitation (transils) ? Thanks Regards
2023-12-15 03:50 AM
Welcome @DM-Electron, to the community!
Ideally, you should include a photo of the device with such enquiries. However, I assume from your information that it is the LM293D, i.e. a dual voltage comparator.
Hope that helps?
/Peter
2023-12-15 03:50 AM
Hope that helps?
/Peter
