Is it possible to change/modify the spice model of MOSFET?
Actually, I want to observe switching behavior of MOSFET with different Threshold Voltage Vth. So can we change the value of Vth in spice model?
‎2023-05-22 06:05 AM
‎2023-05-22 06:19 AM
Welcome, @Subhash​, to the community!
even if this were possible, why would you want to change a SPICE model?
It is originally designed to represent the real data of the MOSFET in a simulatable form. If you change this data, the model no longer corresponds to the physical device and can only be investigated theoretically and the result is no longer practically relevant?
/Peter
‎2023-05-22 06:52 AM - edited ‎2023-11-20 04:54 AM
Hello @peter BENSCH​
I want to check switching behavior of MOSFET with various Vth voltage (as mentioned Vth range in datasheet). I am doing simulation on this part number: SCT012W90G3AG_V3 in LTspice. Datasheet shows range of VGS(th): 1.8 V(min), 3.1V (typ.) and 4.2V (max) as per following snapshot.And I also observed one specific note on spice model like dR=0 dVth=0 dVsd=0 dCi=0 dCr=0 dCo=0.
Could you tell me, why this one is given with spice model?
Subhash
![](/skins/images/B042DBD9233DBE51255C3729EC4F3C6A/responsive_peak/images/icon_anonymous_message.png)
