Instruction cycle and program space.
ongth60
Posted on April 20, 2005 at 07:12
ongth60
Posted on April 19, 2005 at 02:18
Hi all,
1. What options are available to check the size of my program code?
2.Since my application is time-critical, how can i measure the time taken for a function to execute? Also, what is the period for one instruction cycle?
3.How many instruction cycles will a C statement take, for example:
TIM1->OCBR += 0x9C40;
Warm regards,
TH Ong
ongth60
Posted on April 19, 2005 at 23:11
If then, how can I measure the time taken by a function if my appliction is time-critical?
Rgrds,
TH Ong
hichem2
Hi ongth60,
As RISC said is not easy to know the execution time for ARM instructions, so if you want to measure the time taken by a function, you can use the TIMER(at the beginning and the end of the section code) to do it.
Hich :o
