Identify this Unknown component?
2024-12-11 12:48 AM - last edited on 2024-12-11 12:49 AM by Andrew Neil
Hi, I'm having trouble identifiying an ST part from marking code.
Component is a 8 pin IC.
Code is as below:
First line: 3s128wt
First line: k952k
Thank you !
Best regards, M
IO-Link
2024-12-11 10:24 AM
35128WT
Looks to be an EEPROM, custom part from BOSCH by the looks of it
http://blog.obdii365.com/2024/06/19/bmw-cluster-35128wt-with-yanhua-emulator-dp4-or-cg-pro/
https://community.st.com/t5/others-hardware-and-software/looking-for-35128-datasheet/td-p/405924
2024-12-11 12:51 AM
You've posted in 'Interface and connectivity ICs' - does that mean you have reason to believe that it is an 'Interface' or 'connectivity' IC?
Similarly with the IO-Link tag?
2024-12-11 1:09 AM - last edited on 2024-12-11 1:16 AM by Andrew Neil
Hi, I accidentally done that, I wanted to post in Others: hardware and software, since I believe is EEPROM device.
will try to re-post it in that discussion and delete this one.
I apologize..
I've moved it for you.
2024-12-11 9:25 AM
@Matja Please upload a legible photo of your device.
/Peter
2024-12-11 10:24 AM
35128WT
2024-12-11 4:40 PM
You are correct, i didn”t saw that as a 5, thank you very much for your help ad solving my issue !
I was hoping to find the part number in order to buy it from Farnell/Mouser, but I see this is a custom part…
Wish you a good day !
