How can I get 1ms timer with ST7LITE1xB ?
Options
2006-09-25 3:23 PM
Posted on September 26, 2006 at 00:23
Labels:
- Labels:
Legacy Products
1 REPLY 1
Options
2006-09-25 3:23 PM
I want a 1ms timer with ST7LITE19B.
Should I use the LITE timer or the 12-bit autoreload timer? Which register should be set? and what value is needed for each control register? For example, to get 8MHZ fcpu, I set the OPTION BYTE as follows : CLKSEL = 1 1 PLLx4x8 = 1 PLLOFF =0 PLL32OFF = 1 OSC = 0
