HI, We are storing some values to Emulated EEPROM using on-chip Flash memory. It was working fine for few months suddenly its reading nothing from the memory. Then we downloaded the same firmware again and its started to work. Why its happened?
pratheep
1 REPLY 1
Ozone
Lead II
That is barely much useful information to work on.
> It was working fine for few months suddenly its reading nothing ...
If you can't find a reason by static code review, try to simulate the "few month" by either tweaking variables or speeding up the regular events.
When you can reproduce it, you can investigate and debug it.
