Flash Update only?
Options
‎2003-01-16 8:31 AM
3 REPLIES 3
Options
‎2011-05-17 2:53 AM
Posted on May 17, 2011 at 11:53
Using the PSDsoft Express (v7.70) it looks as if the PLD is reconfigured
with every Flash update also. On the other hand I understand, PLD can be reprogramed less often than Flash memory. Is there a way to keep the PLD unchanged while updating Flash memory only?Options
‎2011-05-17 2:53 AM
Thank you!
It works. I feel better now.Options
‎2011-05-17 2:53 AM
In Express software, when you do the last operatin: JATG/ISP, you can select Flash in 'PSD region ' part of step2 in dialogbox of JATG/ISP Operation. So that you can undate the Flash memory and keep other.
