2004-03-21 4:49 PM
2004-03-18 1:16 AM
I want to make IAP with the ST72F264 Family but i need to use the emulated eeprom .
To use this feature i need to write byte to a specific spot on the address space and i understand that the micro will stop the normal function go to IAP mode without Interuppts also . What is the easy way to do so . Latino from Israel2004-03-21 4:49 PM
For your application, AN1477(Emulated Data EEPROM with XFlash memory) is available on this same site.
