2008-10-15 6:07 AM
2011-05-17 12:56 AM
How create a digital toggle signal on GPIO4 for the STR9-comstick ? I create it but the maximum frequency is 300KHz with jitter on the signal. There is a way for higher frequency ? regards2011-05-17 12:56 AM
Use one of the timers to generate your clock signal.
You'll get much better control and no jitter (well, as much as your original clock source has).
