Code for setting configuration register
‎2007-05-18 12:25 AM
- Labels:
Legacy Products
‎2011-05-17 12:42 AM
Hi
Can anyone supply me with code for setting Configuration register for changning the boot to bank1, so I can use it instead of the CAPS Is it the CSX bit ?- Mark as New
No one responded to my earlier post on this, so I assume it is absolutely impossible to set the CSX bit without using JTAG.
I read more about it and now I understand it can only bee done via JTAG, but how. With JTAG it depends on the IDE system, and maybe it can bee done
by setting registers in the init sequence I using iSystem and winIDEA, anyone know how to setup the JTAG ??- Mark as New
The fastest way of doing it is using ST Micro's CAPS program, and a Raisonnance RLink jtag adapter.
Otherwise, you will need to study the STR91x Flash Programming manual, which has the details of JTAG bit banging, but that requires knowledge of the jtag protocol (I gave up after a while).- Mark as New
Hai,
you can change the csx bit in 91x_CFG.s which will be available in strtup code folder for ST.We are using keil ide.You can add 91x_CFG.s to startupcode and select the csx bit and download the program using JTAG.- Mark as New
I will give you some tips.
First of all find in your project the (output) map file like the example is attached. In attached file you will find: Load Region LR_IROM1 - code Execution Region RW_IRAM1 - ram Load Region LR$$.ARM.__AT_0x520000 - configuration this means that after linking we have code that intended for addresses 0x520000 - 0x520007 Now the programer knows that it must write to flash also this addresses.- Mark as New
I use the attached file. But if this file not compatible for your system
you must create code area yourself (see the attached as example change it to your system if needed). When you receive in your map file the code area that i explaned before - one step is done. Now may be the programer that you use can not write that area(no algorithm). Check it before you start. Than may be it easier to use the caps. Or find the programer that can program any hex file that support algorithms for different area writing. Good luck!!!
