CiA417 CANOpen protocol in STM32
Vrushabh_Kale_1157
We need to integrate CiA417 CANOpen protocol for one of the application. Please suggest suitable STM32 micro-controllers and related documentation.
Thank you
SofLit
Any STM32 having CAN interface peripheral can run CANOpen. For this, you can use STM32CubeMx or STM32Cube Finder tools .
For stacks:
Open source: CANOpen implementation on STM32:
https://github.com/CANopenNode/CanOpenSTM32/tree/master/CANopenNode_STM32
https://github.com/cooleo2/CanOpenSTM32G4
Commercial: CANOpen from ST partner Emotas: https://www.st.com/en/partner-products-and-services/canopen.html
Contact: https://www.emotas.de/en/contact
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
6 REPLIES 6
MHoll.2
Senior
Any STM32 MCU with integrated CAN-Bus Controller is suitable to implement the CANopen Stack.
You have to specificate what other requirements You have.
Vrushabh_Kale_1157
Thanks @MHoll.2, our requirement is STM32 controller supporting Ethernet. Is there any documentation or links regarding CANOpen stack or any sample code/project which will help me to implement it.
Thank you,
Vrushabh Kale
https://www.st.com/content/st_com/en/stm32-mcu-developer-zone/mcu-portfolio.html
give's You the possibility to find the best STM32 for Your needs.
As for the CanOpen Stack, there are some comercial offers (Integrated in STM32CubeIDE you find emotas).
If You are looking for a opensource solution, I'm using CanOpenNode (https://github.com/CANopenNode).
But You need to implement CiA417 by your self.
SofLit
For stacks:
can you briefly explain the implementation method?
The implementation is divided in two:
1) Generating the Object Dictionary and the PDO's, this is normaly done with a PC tool (for example CanOpenNode has a tool called EDSEditor)
2) Connecting the Data to Your application.
In any case You need the CiA 417 standard documentation, an at least a "basic" understanding how CANopen works.
