2004-04-01 8:22 PM
Alternative flash programmer for ST9
2011-05-17 2:34 AM
Hi, anyone can suggest a faster (than STVP) flash programmer for ISP programming of ST92F150?
Thanks2011-05-17 2:34 AM
What about the Segger Flasher. It should be optimized for Volume Production.
2011-05-17 2:34 AM
hi!
we developed a small and flexible in-system-programming-box, which allows to programm the ST9x devices. Simply connected to PC via RS232, it is possible to run scripts for predefined actions, i.e. RESET, FLASH-ERASE, PROGRAMM, LOAD-BOOT-APPLICATION, ... even it is possible to run own small programms in the internal RAM without programming the flash! is anyone interested? email me. regards, siggi2011-05-17 2:34 AM
Sure, can you tell us more about your tool, how you came to develop it?
2011-05-17 2:34 AM
2011-05-17 2:34 AM
Do you belong to a company involved with Devt Tools or did you design this programmer to solve your own application problem.
2011-05-17 2:34 AM
2011-05-17 2:34 AM
Hi siggi
Your tool looks good! If you use ISP, you probably need HW between your application and PC? Is it working as the ST programming board? I mean with another micro as a master...?2011-05-17 2:34 AM
Hello Siggi,
Hoping to hear from you soon.
