2022-04-02 9:59 PM
2022-04-02 10:04 PM
2022-07-11 11:51 AM
It is most likely a customized part that only the respective customer is authorized to make a statement about. So you would have to ask the manufacturer of this board about this part.
I've used a web based translation service to translate the answer:
我使用了一个基于网络的翻译�?务�?�翻译这个答案。
这很�?�能是一个定制的零件,�?�有相应的客户�?有�?�进行申报。因此,你必须�?�这个�?��?的制造商询问这个零件的情况。
Good luck!
/Peter
2022-07-11 12:11 PM
ST 1825-0369 TSSOP48
