writing to flash databank 0
ezanen9
Posted on November 02, 2006 at 12:09
ezanen9
Posted on April 26, 2006 at 11:47
Hi all,
I want to write to flash databank 0 three(3) different integers values. I want to write these values at different times to the same bank in the flash but at different adresses.
There is a programming example in the ST library's.
/* Initialize the FLASH */
FLASH_Init () ;
/* Disable the FLASH protection on Bank 1 sector 0 */
FLASH_WritePrConfig (FLASH_B1F0,DISABLE) ;
FLASH_SectorErase (FLASH_B1F0) ;
/* Write 0x12345678 to Bank 1 sector 0 */
FLASH_WordWrite (0x000C0000,0x12345678) ;
/* Warning!! : The write protection can be enabled only on a permanent way */
/* Enable the FLASH protection on Bank 1 sector 0 */
/* FLASH_WritePrConfig (FLASH_B1F0,ENABLE) ; */
My questions are:
1. Do I always have to clear a flash bank prior to each writing to it?
2. If I wrote one value to the flash at for example adress 0x000C0000 is it still possible to write a second and a third value? Or do I have to write all the data to the flash at ones?
3.What meens the following in the example: ??
Is it ever possible to write to the flash after the above has happend?
Hope somebody can help a little bit,
Jimmey
ezanen9
Posted on April 27, 2006 at 12:47
Thanks RISC,
It works perfectly.
I only have a problem writing float value's to the flash.
float fPort=0; //init
fPort = 22.64; // fill float with value
FLASH_WordWrite (0x000C0044,fPort); // write float to flash 0x400C0044 adress
When I read the float back from the flash the problem is that only 22(0x00000016) is written to the flash. The .64 missing.
I also saw this with my memory view via the JTAG port. What's my mistake?
Perhaps the float doesn't fit in the 32 bits space??
Jimmey
macke_a
Hello !
I already have to use the programm example in the ST library which looks in the first thread of Jimmey. But this one dosn´t work by me....
I use the Keil µVision3 and a STR710FZ µControler.
Could somebody help me, from this problem ?
I think some adjustment parameters a wrong!
u32 Read_Data;
FLASH_Init () ;
/* Disable temporarily the FLASH protection on Bank 1 sector 0 */
/* Erase Bank 1 sector 0 */
/* Read back the written data at address 0x400C0000*/
Read_Data = FLASH_WordRead(0x000C0000);
The Read_Data out gives me a wrong value back
Thank you...
