WDG, free runing timer
popov2004
Posted on September 28, 2007 at 14:37
popov2004
Posted on September 28, 2007 at 07:25
Hi All,
I am using the WDG free runing timer mode in order to make the couter counting 5s.
I would like to print (begining) continue executing the programm, after 5 second print( END ).
with out stopping executing the program.
here is the code, could any one tell me where is the problem ?
printf(''\r\n Beginning ***************************'');
WDG_ECITConfig (ENABLE);
WDG_CntOnOffConfig (ENABLE);
WDG_PeriodValueConfig (5000000); /* 5 s*/
/* EIC peripheral configuration -------------------------------------------*/
EIC_IRQChannelPriorityConfig(WDG_IRQChannel, 1);
EIC_IRQChannelConfig(WDG_IRQChannel, ENABLE);
EIC_IRQConfig(ENABLE);
hStatus = WDG_ECStatus();
if (hStatus==1){
printf(''\r\n END ***********************\r\n'');
WDG_ECFlagClear();
kleshov
Without trying to check if initialization sequence is correct, I can point out two things. First, do you need the watchdog interrupt for this? Seems not. Second, surely you should use a loop to check if the timer has expired, rather than an 'if' statement?
while (WDG_ECStatus() != 1) { /* empty */ }
printf(''whatever...'');
