2024-08-15 02:32 AM
Is this available anywhere?
This is the Mahindra Scorpio Car BCM chip
2024-08-15 03:08 AM
Welcome @Raztheripper, to the community!
This is probably a customised component, as only VND5025AK-E is still in production and available. The specification of that customised part is then only available from the respective vehicle manufacturer.
The VND5025AK-E is most likely pin-2-pin compatible. You could try using this as a replacement, but its current sense ratio might not be accurate enough.
Hope that helps.
Good luck!
/Peter
