vector.s for Anglia IDEaliST
gflasza
Posted on November 21, 2007 at 13:57
14 REPLIES 14
mehdi239955
Posted on May 17, 2011 at 09:41
Hi
Can you provide me with more details.
Did vectors.s works with only one interrupt?
regards
MBS,
[ This message was edited by: MBS on 10-04-2007 11:26 ]
gflasza
Hi
I looking for working vector.s file for Anglia Compiler
I've got the standard vectors.s, but it doesn't work with two interrupts (from VIC0 and VIC1)
[ This message was edited by: GrzesiekFl on 10-04-2007 10:33 ]
gflasza
I have two interrupts : one from TIM0 and one from UART0. When I use two interrupts I lose chars from UART0, but when I use ONLY TIM0 interrupts it works correctly
mehdi239955
Hi ,
Please find attached a project (RIDE/IAR/RVDK) with two interrupts and note that RIDE is using GNU compiler (GCC-ARM) so, you'll find the necessary modification needed to vector.s in 91x_init.s .
MBS
[ This message was edited by: MBS on 13-04-2007 15:51 ]
kmshim
Maybe your problem will be the cause of nested interrupt.
also, I had same problem. would you modify the IRQ handler as following in the vect.s
IRQHandler
SUB lr,lr,#4 ;// Update the link register
SaveContext r0,r12 ;// Save the workspace plus the current
;// return address lr_irq and spsr_irq
LDR r0, = VectorAddress
LDR r0, [r0] ;// Read the routine address
;//LDR r1, = VectorAddressDaisy
;//LDR r1, [r1]
;// Padding between the acknowledge and re-enable of interrupts
;// For more details, please refer to the following URL
http://www.arm.com/support/faqip/3682.html
;//NOP
;//NOP
;//MSR cpsr_c,#0x1F | I_Bit ;// Switch to SYS mode and disable IRQ modified by KMSHIM, 2007/03/15
;//MSR cpsr_c,#0x1F ;// Switch to SYS mode and enable IRQ
STMFD sp!,{lr} ;// Save the link register.
LDR lr, = IRQ_ReturnAddress ;// Read the return address.
BX r0 ;// Branch to the IRQ handler.
IRQ_ReturnAddress
LDMFD sp!,{lr} ;// Restore the link register.
;//MSR cpsr_c,#0xD2 | I_Bit ;// Switch to IRQ mode and disable IRQ
LDR r0, = VectorAddress ;// Write to the VectorAddress to clear the
STR r0,[r0] ;// respective interrupt in the internal interrupt
LDR r1, = VectorAddressDaisy ;// Write to the VectorAddressDaisy to clear the
STR r1,[r1] ;// respective interrupt in the internal interrupt
RestoreContext r0,r12 ;// Restore the context and return to the...
;// ...program execution.
good luck!!
best regards,
KMSHIM
mehdi239955
Hi KM SHIM,
i think the problem of spurious interrupt are now solved with the different modifications that we have done on Vector.s and it.c .
have a look to IRQ project which i send previously.(waiting for your feedback 8-) )
MBS
[ This message was edited by: MBS on 12-04-2007 11:52 ]
kmshim
Hi, MBS
Mode switch that you have done have been implemented in the IRQ handler.
I think that there are jsut differences as like nested interrut and writing to VICx->VAR.
Are there any difference in the your code?
best regards,
KM SHIM
mehdi239955
hi,
I didn't understand your question :( .
The example which i sent,is a solution to generate correct nested interrupt with VIC0 and VIC1 without any conflict .
did you try it?
MBS
[ This message was edited by: MBS on 12-04-2007 16:24 ]
mehdi239955
hi all,
i've done the portage of IRQ project to anglia IDE. :-]
keep me informed about any issue.
regards.
MBS 8-)
[ This message was edited by: MBS on 13-04-2007 17:38 ]
