usb control read
sjo
Posted on May 16, 2006 at 13:21
usb control read
9 REPLIES 9
sjo
Posted on July 25, 2005 at 06:58
I have written a dfu driver for the str711 device, all works ok except control read transfers (OUT transfers).
I have traced the problem down to the usb interrupt routine (CTR_ISR) - This function below checks for a setup packet but the mask will also catch all RX (OUT) transfers including non SETUP ones. In other words the Out0_Process will never get called.
if((wEPVal & (EP_CTR_RX|EP_SETUP)) != 0)
_ClearEP_CTR_RX(ENDP0); /* SETUP bit kept frozen while CTR_RX = 1 */
Setup0_Process();
else if((wEPVal & EP_CTR_RX) != 0)
Out0_Process();
changing to
if((wEPVal & (EP_SETUP)) != 0) fixes the problem, is this correct ?
sjo
sjo
Posted on July 27, 2005 at 13:50
Could anyone confirm what I have done is correct ?
sjo
hichem2
Posted on July 28, 2005 at 07:01
Hi Sjo,
Sorry for the delay...
We have already checked the USB software libray and some mistakes are alredy verified(The new version is not published yet).
Concerning the Out0_Process section we use the following condition .
if((wEPVal &EP_SETUP) != 0)
Setup0_Process();
Out0_Process();
With best regards,
Hich :-o
[ This message was edited by: Hich on 28-07-2005 12:45 ]
cgrun
Posted on September 22, 2005 at 16:38
You inform us that you have a new version of the usb library.
Could you publish it ? even if it's unsupported, because we use the current library that have some problem...
Sincerely
Chris.
cgrun
Posted on October 02, 2005 at 17:23
Can you puublish this new version of the usb library ?
cgrun
Posted on February 09, 2006 at 05:54
Did have you any news for the usb lib?
Chris.
hichem2
Posted on February 09, 2006 at 07:16
Hi all,
The STR71x USB software package review is on going and planned for W13.
Then it will be published as soon as possible.
Thank you for your comprehension.
With best regards,
Hich ;-)
shangdawei1
Posted on February 23, 2006 at 08:43
Quote:
On 09-02-2006 at 11:46, Anonymous wrote:
Hi all,
With best regards,
Hich ;-)
will it be published before April 1 ?
cgrun
Did have you any news for the usb lib (We are in week 20)?
Chris.
