STR912FAW44 IAP programing fails after 8192 bytes
lloydepowell
Posted on June 24, 2009 at 19:27
10 REPLIES 10
gupta2
Posted on July 06, 2012 at 11:28
Hi..
I am working on str912faw44 and keil microvision 3. I am also facing the similar problem as mentioned above, i am also not been able to write more than 8192 bytes in bootloader program. I read this forum and tried after changing CSX bit through str91xCFG.s file , but no benefit..even i started getting the problem ..
No algorithm found for : 00510000-00510003 H
No algorithm found for: 00520000-00520007H
Any idea what should i do.Please help.
