STR750 : TIM PWM input capture (with PWM signals < 2kHz)
xaviooo
Posted on June 14, 2007 at 08:40
xaviooo
Posted on June 12, 2007 at 14:24
Hello everybody,
Using the Timer PWM input capture example, i'm trying to get the duty cycle of a PWM signal whose frequency is below 2kHz with CK_TIM = 60 MHz.
It works when f > 2kHz, but not with a 1800 Hz signal.
Thank you for your help.
-Xavier
kaouther
- using CK_TIM = 60 MHz, it is possible to measure the frequency and
duty cycle of a PWM signal frequency of 915Hz.
what is the prescaler value set when measuring the 1800Hz signal?
