2003-09-18 05:10 AM
2003-09-04 03:04 AM
Hello !
I'm currently developping a man machine interface for embedded equipment using STPC Atlas. The MMI has been developped with STPC Gfx Libraries, using a CRT monitor for testing. Now i would like to use a TFT monitor (NEC) which is part of the embedded equipment. The Reference is NEC NL3224BC35-20 What are the steps to follow in order to get the TFT screen working ? (modifications in the init, etc) Thanks2003-09-18 05:10 AM
The best route that you can follow is if your TFT is VESA compatible, is to take an existing graphics BIOS that is available on this web site at the URL
- BIOS and patch it with Elpin Binary editor that is located at - Utlity and look for the key text ''STPC BIOS Graphics Binary Editor''. Use the binary editor to patch your timings into the BIOS and then just reflash the graphics BIOS with you system BIOS.
