ST7VD programs and verify, but application won't work
martinh
Posted on May 29, 2008 at 16:48
martinh
Good afternoon to all,
I'm struggled with a problem and I would appreciate very much your suggestions:
I'm working with ST7VD as IDE and Cosmic Tools as compiler.
When programming, everything is fine, the program is written and verified but my application won't work properly.
Programming...
PROGRAM MEMORY:
> Erase not feasible
> Programming
System Memory Revision in device: 0
done
> Verifying
done
I already tried a very simple program (blink a led), in a prototype board mounted only with the chip and its ICP hardware setup, just to test the programming, with no success.
The same problem happens with two kind of chips, the ST7LITEU09 and its equivalent debug package :-?
Could you please point me out where am I wrong?
Thanks in advance for your attention!
Martin
