ST7ULTRALITE INTERNAL RC OSCILLATOR
Posted on April 06, 2007 at 07:19
Posted on April 06, 2007 at 07:07
The predefined calibration low byte value of rc calibration for 5V(RCCRL0) is located in 0xDDE1, but what is its format?
The 2 bits CR0-CR1 where are locate?
Thank you in advance for help.
laurent239955_stm1
They are located on bit 5 and 6, so you don't need to perform any shift to copy them in SICSR register.
You have to take care about :
- LVDRF bit which will be cleared by reading the SICSR register, so this check must be performed before setting the RC calibration or the SICSR register must be saved in a variable.
- AVDIE : which will be clear if you don't mask it
For more information about SICSR, refer to datasheet.
Best regards
Laurent
