ST72F521 programming
tayfun
Posted on October 02, 2003 at 05:59
tayfun
Posted on September 30, 2003 at 10:43
During ST72F521 programming with St7-STICK, when the option byte is changed from External Osc to Resonator OSC, after that the device can not be re-programmed and the following error messages are got :
Error : Cannot communicate with the device ! Option Bytes are Disabled on the device
Check the ICC cable connection and check all the needed pin connections on the ICP connector
Clock is 'External source' in this ICP mode
Or
Error : Cannot communicate with the device ! Option Bytes are Enabled on the device
Try the other programming mode:'ICP OPT Disable' in order to check the Options
Bytes on the device (Clock Source,PLL,LVD) compare to the application configuration
On Application, connect OSC pin from ICP connector or an Oscillator or a logic clock
Tayfun
jatin
Follow the procedure defined in the second error message i.e.
''Try the other programming mode:'ICP OPT Disable' in order to check the Options Bytes on the device (Clock Source,PLL,LVD) compare to the application configuration. On Application, connect OSC pin from ICP connector or an Oscillator or a logic clock''.
After following the above, now change your clock source to resonator oscillator.
