2004-03-28 09:54 PM
ST72324 - emulator error - undefined memory access
2004-03-23 08:19 AM
I'm using the DVP3 emulator board, configured to work as ST72324.
I get this ERROR which I cant resolve - can someone please help... ERROR - stopped on undefined memory access at 0x752004-03-23 08:10 PM
Hi Shlomo1,
>>Please check your *.h, *.c/*.asm files in which you might have assigned a register in that address(0x75) or else find out where exactly this error is appearing by using step into function so that we could findout the cause. >>If you are using any pointers be cautious! sometimes this may give you this kind of error. >> Please check your *.prm (Metrowerks) or the relevant files where the address mapping is done. (IMPORTANT) >>Also, Please check the type of memory in the ''MCU configuration'' window. With Regards Krsel2004-03-28 09:54 PM
You are trying to access the reserved area of the memory.
