2010-06-14 06:01 AM
The ICC Protocol Reference Manual Appendix 1 is an ICC Monitor that I would like to use in a programmer I am writing for the ST72F324. It appears that the icc_drv.asm file is using the upper 252 bytes of the reserved memory for the program. I haven't found any document that describes this approach for other micros.
Am I to assume that I can use the upper memory space of the reserved memory area of any ST7?
