2002-12-03 11:01 PM
ST7 In-Application Flash programming
2002-10-18 10:59 AM
I'm using the inDart debugger with a ''toolchain'' of Cosmic C compiler / Linker. Is there a library for ST7 in-application programming (as opposed to the In-Circuit Programming provided by inDart)?
2002-10-18 12:34 PM
I have not find any application note on in-application programming (IAP) with ST7. There is only the Flash programming user manual that explains you how to write code for IAP. This document can be accessed with the link below :
Regards, Jojo2002-12-03 11:01 PM
hi,
You find in this site two demo applications build on XFlash and HDFlash drivers they contain : - demo guide - driver - all programming environnement for thr demo (sources, drivers, config) to try these software , use .S19 file . and if you want to modify the software you can rebuild it by invoking the batch file. Best Regards MM
