2006-12-18 07:28 AM
2006-12-17 08:08 PM
when I'm loading the ST10flasher.dll into my program its trying to parse a file ST10Flash.cfg. What's the purpose of this file (is it necessary for a correct functioning)? Could you give me an example of how it has to look for the ST10F276?2006-12-17 08:27 PM
The ST10Flash.cfg file gives a description of the Internal Flash in all ST10 derivatives( Start address, End address, Blocks, sizes...). This file is used with the last ST10Flasher Version: V4.2B. You can find find it in PATCH_018UM.zip (in the ST10Flasher V4.2B package) which should be unpacked into the ST10Flasher installation directory. You can find the ST10Flasher last version on the following link: http://www.stmcu.com/modules.php?name=mcu&file=familiesdocs&FAM=17 Regards, Najoua.2006-12-18 07:28 AM
Thank you, it works fine!
2010-03-31 01:35 PM
