2007-11-09 06:43 AM
2007-11-07 11:43 AM
Hi, I am now using LM4040A50IDBZR for VAREF.
My problem is I only get about 2v on VAREF pin, sch attached. I used it on C167CS, no problem at all, would you please give me some idea why this happened. Also any recommend for voltage Reference chip for ST10F269 or ST10F276 thank you ________________ Attachments : ST10F269.JPG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Ks&d=%2Fa%2F0X0000000bXn%2FAjf2IE4BGz..IZ_mu5pna3Xp1MTnU4XCS4DsLf6399M&asPdf=false2007-11-08 11:48 AM
BTW: REG is 12V or 24V
2007-11-08 10:11 PM
Hello jasonsyj,
The problem might be caused by the difference in Iaref on both devices. You can refer to the enclosed schematics of the FS FORTH boards based on the ST10F269 and the ST10F276 for more details about the hardware on VAREF pin (page 2 ). I hope this helps you. Best regards, Najoua. [ This message was edited by: Najoua on 15-11-2007 13:19 ] ________________ Attachments : Eva269_0.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0GI&d=%2Fa%2F0X0000000bXl%2FHOtcdBZCK_gNYN6O1TAnYK4dh2LAGztXE7QdAEZ98X4&asPdf=falseEva27x_0c.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0ID&d=%2Fa%2F0X0000000bXk%2FcTe9ebB1N5MtJZB46WvG7Fsv2LxG.koGOWbV8M4oa8U&asPdf=false2007-11-09 06:43 AM
thank you for your help
but what part number for V4 on your sch? thank you again
