ST10F269 MAC question
a_shemet
Posted on February 23, 2006 at 07:29
a_shemet
Posted on February 17, 2006 at 05:12
Hello!
According to manual on ST10F269 MAC unit, command coMOV can be used for data transfer to the entire memory space:
''The GPR pointer allows access to the entire
memory space, but IDXi are limited to the internal Dual-Port RAM, except for the CoMOV instruction.'' (ST10F269 User's manual, rel1.2, page 62)
My questions is:
Does ''entire memory space'' means total 16-Mbytes range?
How can I do it? All these registers are 16-bit wide, so I suppose, that additional registers also should be used as page registers ?
a_shemet
Posted on February 21, 2006 at 11:03
Neila, thank you for yor reply!
I know about DPP0...DPP3 registers, but it is not clear for me, how to use them together with MAC registers.
There is another way to get access to any memory location:
extp R12,#1
mov [R10],R1
, for example.
For me, it is also not clear, should I use similar sequence, like
extp R12,#1
coMOV [IDX0+],[R11+]
, when I use MAC registers?
Is it possible to get some examples, where this issue described more detailed?
Thanks in advance, Shandy
