Software reset
fa
Posted on March 14, 2007 at 04:39
Software reset
10 REPLIES 10
ben2
Jumping to the reset vector will work, but you have to be careful as it is not the same as a proper reset, in that registers/interrupts will not be reset. At the very least I would disable any enabled interrupts before jumping to the reset vector. There is also a section in the datasheet (EIC IRQ notes) that is worth reading if you are going to do this.
