Simplest way for ISP with ST72C215
flashwolf
Posted on May 25, 2004 at 11:07
5 REPLIES 5
flashwolf
Posted on May 03, 2004 at 11:41
Hi all!
I have a ST72C215G2B6-based device with ISP connector on it. I've found that Visual Programmer can do it's job through LPT port. So, the question is: how to build the simplest programmer?
Sorry for ''stupid'' question, but this is my first ST MCU... I have some experience in MCS-51, AVR, PICs - but not in ST
md1
Posted on May 10, 2004 at 14:36
Check out flashbash: www.spen-soft.co.uk
alain2399
Posted on May 11, 2004 at 07:16
Flash Bash has its own PC software and does not needs to be connected to a PC to operate.
If you want to use the ST Visual Programmer PC software you can build your own low cost LPT programmer using the STICK schematics/Bill of materials/gerber files that are available on this web site.
[ This message was edited by: Alaini on 11-05-2004 10:47 ]
md1
Posted on May 25, 2004 at 10:21
Just to point out: Flashbash operates in PC mode and stand-alone mode.
Cheers,
Marty.
ldefend1
please take a look at
http://www.softecmicro.com/products.html?type=detail&title=inDART-ST72C/SK
If you want to use a reliable solution you can choose inDART from SofTec Microsystems.
