simple IAP with ST7
lseletron
Posted on May 18, 2005 at 08:23
simple IAP with ST7
lseletron
Posted on April 29, 2005 at 00:36
I want to use ST72F264 in my design. I also want to be able to save certain information (look-up tables etc.) in the flash memory of the chip. I looked through AN1576 but it seems too complicated for what I want to do. Is not there an easier way just to write a number of bytes in flash.
venkateswara
you can write the Flash( except sector0) using the IAP. You can do a simple IAP to write the required locations for permanent storage.
See AN1477 for the necessary information.
hope this helps
