Remote frame on CAN Bus
arnaud
Posted on August 02, 2007 at 05:06
truf9
Posted on May 17, 2011 at 09:45
I yet have made a Remote frame.
The object is declared as CAN_SetRxMsgObj(Remote_Frame,....);
If I receive the remote frame in the interrupt the object will be changed to transmit. This is done automatically from the STR9-Can with the receive of a RTR-Bit. Then I send on the same object (proper a receive object) the reply-message.
The automatical reply of the remote frame doesn't work, because I have to toggle a bit in the reply-frame.
Good luck
arnaud
I have to send remote frame on the CAN Bus with the ST library (CAN_SendMessage function). How can i do that ?
Arno
