2005-03-02 09:41 PM
2011-05-17 03:06 AM
Has anybody experienced problems with the PWM4 on the uPSD3200 series ?
Chip=uPSD3234A PWM4W=5 PWM4P=10 fosc=24MHz Prescaler1 determines PWM4 output frequency. A problem occurs when the Prescaler contains 0080h. All other values appear to give an expected output from PWM4, but this value yields an inconsistant result, where the output pulse determined by PWM4P is correct, but the pulse determined by PWM4W is about 50 times what it should be. Is this a know problem with the uPSD3200. Are there any published documents concerning this problem ? Is there a work around ?
