Problems when build ucLinux imagefor STR710-Eval board.!!!
ladykiller_lkp
Posted on October 11, 2007 at 09:32
ladykiller_lkp
Posted on September 26, 2007 at 08:31
Hi all...I have a problem when build ucLinux image for STR710-Eval board.
when i try the build of uClinux
excute command
make user_only
but It stops with the below mentioned error:
gcc - I/usr/include - o build/erase erase.c
erace.c: 9: 27: error: linux/mtd/mtd.h: No such file or directory.
As for having used
-uClinux-dist-20040408
-arm-elf-tools-20030314.sh
-uClinux-dist-20040408-str710-patch.tar.gz
i've done according to the manual Aplication Note (Getting Started with uClinux for STR71x)
anyone help me to solve this problem
thanks very much
Judas(sorry ,my English very bad)
[ This message was edited by: Judas on 26-09-2007 12:02 ]
[ This message was edited by: Judas on 27-09-2007 06:50 ]
kaouther
Posted on October 11, 2007 at 06:49
Could you check the mtd.h file if it is available in the directory .../linux/mtd/? it should be created when unzipping the ''uClinux-dist-20040408.tar.gz '' package.
kaouther
In the ''Makefile '' file available in''uClinux-dist/user/mdt-util'' directory, please change the following ; '' MY_CFLAGS = -I/usr/include''
By
''MY_CFLAGS = -I$(ROOTDIR)/$(LINUXDIR)/include''
Let me knnow if this does not solves the problem.
Regards.
