Problem in interrupt mode CAN
jkim71
Posted on April 25, 2007 at 05:45
jkim71
Posted on April 18, 2007 at 10:50
I am new to ST micom and CAN.
I am using STR71x
I have tried CAN code in software library and I have confirmed polling mode operation works well.
But I failed in interrupt mode. I'm not sure this code is only for reference and does not work perfectly.
I guesss the code does not receive CAN message and even does not assign message to variable.
Even CAN_IRQHandler is not reached.
The code only says
// send a pre-defined data frame
(void)CAN_SendMessage(CAN_TX_MSGOBJ, &TxCanMsg[1]);
// reception and release are done in the interrupt handler
wait();
I have tried comparing TxCanMsg[1] with RxCanMsg but I don't think received message will be assigned to RxCanMsg with this code.
Anyone please let me solve this problem
Thanks.
