Port pull ups??
bryan2
Posted on April 11, 2004 at 10:32
Port pull ups??
4 REPLIES 4
danielh1
Posted on May 17, 2011 at 11:59
Good question. These ports have pull-up, see page 49 of the datasheet. At page 147 the input low current is specified to be at least -10uA and at most -50uA. That means the pull-value value is between 100K and 500K. Compare this to the standard 50K (typical) of a traditional 8051 machine. If you are designing a board and you need pull-ups on some input, you should better place external resistors and not rely too much on these internal pull-ups: the lower the resistance the greater will be RFI immunity (at the expense of more current).
Daniel
bryan2
Are we reading the same data sheet(uPSD33xx, not 32xx)? Mine is Sep. 2003, it is only 129 pages. I can't find newer one on ST website.
Bryan
bryan2
Do port1--4 of uPSD33xx have internal pull-ups? If yes, how many ohm? I can't find this kind of information in data sheet. Thanks.
Bryan
danielh1
Sorry, I was refering to uPSD32xx. I don't think that there is any difference for the port specifications.
Daniel
