pll clock prblem str911fm44
mariusz2
Posted on April 12, 2007 at 04:49
mohamed23
Posted on May 17, 2011 at 09:41
Dear MariuszS,
You have just to update and change the last lines of your file called ''91x_conf.h'' to this :
*---------------------- _Main_Crystal frequency value (KHz)------------*/
#ifndef _Main_Crystal
#define _Main_Crystal 11059
#endif
As the recommended /default Quartz used for STR91x is 25MHz for Ethernet Usage. :o
rave
mariusz2
hi all. I have a problem, My CPU not work in pll seting for crystal 11.0592 Mhz. i need 11.0592 X 8, maksimum when CPU Go, is X6, I use caps seting (91x_conf.h). My serial Uart work in speed 9600, when i write in struct. params value : 21676, instead of 9600 (correctly).
UART_InitStructure.UART_WordLength = UART_WordLength_8D;
UART_InitStructure.UART_StopBits = UART_StopBits_1;
UART_InitStructure.UART_Parity = UART_Parity_No;
UART_InitStructure.UART_BaudRate =21676; //!!!!!!!!!!!!!!!!!!!!!!
UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None;
UART_InitStructure.UART_Mode = UART_Mode_Tx_Rx;
UART_InitStructure.UART_FIFO = UART_FIFO_Enable;
UART_InitStructure.UART_TxFIFOLevel = UART_FIFOLevel_1_2;
UART_InitStructure.UART_RxFIFOLevel = UART_FIFOLevel_1_2;
Please help me !!! I d'not new idea, how its make
mariusz2
Thanks for reply, in my config file, exist value for main_crystal :
#define _MCLK_Source SCU_MCLK_PLL
#define _Main_Crystal 11059.20 // In KHz
