2007-04-10 05:58 PM
Facing problem in writing data into flash
2011-05-17 12:41 AM
Hi all,
I need an urgent help regarding writing data into flash. For effectively writing data into flash, it is given in the flash-programming manual that 18th bit of Config. Control Reg. of ARM 966E-S core must be set. I would like to know 1. How to write the assembly code for that and 2. Where to place it I would feel happy if i could get the code as i badly need it. Thank you.
