2007-02-08 03:55 PM
Please recommend a ST7 programmer
2006-04-05 02:33 AM
Hi all !
I have now used ST7 Flash Stick programmer/HE10 ICC interface for a while. For field services etc - kindly recommend a smart and easy to use programmer ( Segger ? ). A couple of them will also be sent to our distributors/service stations for fast and easy upgrades of products at spot. New software from us via for eg. email. Thanks in advance. BR Tomas [ This message was edited by: tomasf on 05-04-2006 15:06 ]2006-04-09 02:35 AM
Hy tomasf,
I use Stick and I very satisfied. If you wish use other programmer ( USB connection based), I have used InDart also. Please see in www.softecmicro.com By2006-04-09 05:02 PM
You can find more information about SofTec products as below webpage:
http://mcu.st.com/mcu/modules.php?name=Content&pa=showpage&pid=21 Or http://www.softecmicro.com/ Of course, the best way is to contact SofTec technical support directly: support@softecmicro.com2006-04-09 07:39 PM
Hi.
What do u need excatly: debugger/programmer for development or programmer for production?2006-04-18 01:54 AM
Hi Luter,
I need a programmer for production and field service as described: For field services etc - kindly recommend a smart and easy to use programmer ( Segger ? ). A couple of them will also be sent to our distributors/service stations for fast and easy upgrades of products at spot. New software from us via for eg. email. BR Tomas2006-04-18 03:52 AM
RLink is a low-cost programmer/debugger supporting ST7. It is powered through USB (no need for an external power supply) and is provided with a programmation executable that makes it very easy to use for field services. Have a look at these links for more information: http://www.raisonance.com/products/RLINK.php http://www.st.com/stonline/products/literature/bd/11967/stx-rlink.htm Vincent2006-04-18 08:52 PM
For production i know only 3 gang programmers:
1) SofTec MP8011http://www.softecmicro.com/products.html?type=detail&title=MP8011A
2) Elnec JetProghttp://www.elnec.sk/jetprog.php
http://www.elnec.sk/jetprog_multi.php
3) BP2610x2 Concurrent Programmer 2-site BP2710x2 Concurrent Programmer 2-site BP2710Mx2 Concurrent Programmer 2-site http://www.bpmicro.com/web/bphome.nsf/unids/82B312E4E44B057886256FC80081C2E6?opendocument&Cat=multi2007-02-08 03:55 PM
SofTec has released a new professional grade ICP programmer,
http://URL=http://www.softecmicro.com/products.html?type=detail&title=FlashRunner
. It is a universal and gangable ISP based programmer. Moreover, it could work in standalone mode or host-based controlled via ethernet, RS-232 or USB. The ISP programmer is especially designed for easy ATE integration for saving production time and cost. I suggest you to check more details from .[ This message was edited by: mcu_newbie on 09-02-2007 05:27 ]
