Need a lil helping hand on accessing the EEPROM on a ST6260
jnievelstein9
Posted on March 16, 2004 at 04:39
2 REPLIES 2
jnievelstein9
Posted on March 15, 2004 at 10:50
Hier a lil routine that works propper on the Epromversion
of the ST6260B.
The same routine does not work on the OTA version of
the 6260C.
Please, I am happy for any hint.
setAD LDI DWDR,0FFh ;
JRS E2BUSY,EECTL,setAD ;
LDI EECTL,00h ;
doAD LDI DWDR,0FFh ;
JRS E2BUSY,EECTL,doAD ;
LDI DRBR,00000001b ;
LD A,SData ;
ANDI A,00001111b ;
SET E2ENA,EECTL ;
doAD1 LDI DWDR,0FFh ;
JRS E2BUSY,EECTL,doAD1 ;
LD EEDat,A ;
goonAD LDI DWDR,0FFh ;
JRS E2BUSY,EECTL,goonAD ;
RES E2ENA,EECTL ;
getAD LDI DWDR,0FFh ;
JRS E2BUSY,EECTL,getAD ;
LDI EECTL,00h ;
getAD0 LDI DWDR,0FFh ;
JRS E2BUSY,EECTL,getAD0 ;
LD A,EEDat ;
ANDI A,00001111b ;
LD EAdress,A ;
SET E2off,EECTL ;
RET ;
Note: EEDat = 10h
greetinx
Joker
[ This message was edited by: JRN-Joker on 15-03-2004 15:23 ]
afabilli9
hi, sorry for bad english
not use set o res in to route for read or write e2prom, but use only LDI eectl,xx
This route work very well on the ST62E65C, first use this route disable all interrupts
rde2p ld a,e2p_id ;adress e2prom
ld x,a
ldi xcount,8
ldi y,dato0 ;adress ram when save the buytes read
ldi drbr,01h ;Select the EEPROM page 0
ldi eectl,00h ;Enable the EEPROM
rde2p1 ldi wdr,0ffh
jrs 1,eectl,$
ld a,(x)
ld (y),a
inc x
inc y
dec xcount
jrnz rde2p1
ldi wdr,0ffh
ldi eectl,40h ;Disable the EEPROM (Low comsuption)
ret
wre2p ld a,e2p_id ;adress e2prom
ld x,a ;adress -> X
ldi xcount,8 ;number byte to save
ldi y,dato0 ;adress ram byte to save
ldi eectl,05h ;Enable EEPROM parallel writing mode
ldi wdr,0ffh
jrs 1,eectl,$ ;check that e2pron not busy
wre2p1 ld a,(y)
ld (x),a
inc x
inc y
dec xcount ;decrement counter
jrz wre2p2
jp wre2p1
wre2p2 ldi wdr,0ffh
ldi eectl,0dh ;Start parallel writing (5ms typical)
jrs 1,eectl,$ ;wait end procedure
ldi wdr,0ffh
ret
