mcb-str9
zahir
Posted on January 19, 2008 at 08:25
mcb-str9
zahir
Posted on May 17, 2011 at 09:49
Hi
We have just got a Keil eval for MCB-STR9, and it works fine with the samples using realview compiler. We want to try and use gcc, and was wondering if anyone has examples for gcc and the MCB-STR9. I assume that the main difference is the startup file? Or is there more? The assembler used for realview has a different syntax and so fails for gcc when using the startup.s provided.
Thx
Zahir
