LCD interfacing
renjith
Posted on June 21, 2005 at 11:42
LCD interfacing
renjith
Posted on June 10, 2005 at 05:02
I am interfacing ST10F269 with Graphic LCD Module based on SED1335 LCD controller. How will I define LCD registers. Please send some examples in C for Keil compiler at the earliest
charles239955_st
I think you are connecting the LCD on the external bus.
What you have to do is select a free address range and define a BUSCONx/ADDRSELx pair to point to this range.
For exemple, if you use the segment 5 to map the LCD, you can use the following define:
#define LCD_register0 *( unsigned int huge *)(0x00050000)
Hope this help.
