Keil write COULD NOT STOP ARM DEVICE
k_arthur
Posted on July 25, 2007 at 06:20
15 REPLIES 15
k_arthur
Posted on May 17, 2011 at 09:40
I have tried uploading from bank 1. I forgot to set bit in the STR9xCFG.s file.
Now i can not reprogram the STR911.Keil write COULD NOT STOP ARM DEVICE.
Anyone knows how to correct this?
d_steffen
http://www.keil.com/support/docs/3215.htm
try this
k_arthur
I tried to do steps writen on
in addition my KEIL Version is 3.04(This sequence is implemented in UL2ARM.DLL V1.20a or higher which is part of MDK-ARM Version 3.02.).It not help.
And i tried to do just full erase -> i receive COULD NOT STOP ARM DEVICE.
Is it means that i must to change the chip on the board ? Please somebody
help me!!!!!!!!!!!!!!!! Pliiizzzzzzzzzzzzzzzzzzzzzzzz!!!!!!!!!!!!!!!
k_arthur
Ibtissem . I have read your detailed explanation of how to boot from bank1.
In this part:
The most important options are:
- BBSIZE 0x32K
- BBADDR 0x0
- NBBSIZE 0x512K
- NBBADDR 0x80000 (and NOT 0x400000!)
- NBBADDR is not obligatory to be 0x80000
Its better to set it -> 0x8000 (32 kb from 0x0) Am i right?
Please check it and answer me. Simply I afraide of STR911.
d_steffen
Keil ARM MDK 3.05 is now valid, may be, erasing a not responding
device is is working only with this newer version, you can download mdk 3.05 from the Keil homepage.
[ This message was edited by: Barricade on 28-03-2007 13:59 ]
d_steffen
A second possibility is to use the ST tool CAPS with
a ST flashlink adapter. Booth solutions worked for me.
k_arthur
Written on chip :
ARM
STR911F
M44X6
HPAEW VG
KOR HP 620
ST
k_arthur
Additional information:
I work with boards developped by firm i work in. And we tried 2 boards
and make the same mistake twise(forget to set bit CSX (may be because
STR91xCFG.s was not added to new project)). The problem is exist on 2 boards. Both boards show the same response.
k_arthur
Hello ibtissem,
thanks for help.
Another question:
BBADDR is obligatory to be 0x0 or it is possible to use another
value in some situations? Simply i do not anderstand why we have
opportunity to change BBADDR.
