ISA Bus instead of IDE
martinwechsler9
Posted on November 13, 2003 at 18:08
martinwechsler9
Posted on November 07, 2003 at 10:00
Does anybody know if I can disable the IDE bus and use only the ISA bus.
If that´s possible, is there a way to generate internally the chip selects when the IDE Bus is disabled?
The fact is that I cannot use the IDE bus but I need to access a Hard drive. I could implement it on the ISA Bus, but i need the chip select signals. Unfortunatelly I don´t have enough room to place any kind of decoder.
If anyone has a clue...
Thanks.
marios
You message misses details for an answer from the people:
- what CPU are you using?
- ISA and IDE almost share the same lines, why can't you use the IDE?
- can your BIOS allow you to use a USB hard drive?
